42
I searched and couldn't find a solution for this anywhere. I'm using PuTTY from Windows to connect to various servers where I run bash and screen. It seems bash works fine with ctrl-arrow keys to jump word-to-word on the command line but within screen it's not working. Not in screen, ctrl-left sends "^[OC and ctrl-right is "^[OD". Within screen I instead get "^[[C" and "^[[D", which appears to be the codes for just the left/right arrow keys. Is there any way to get screen to recognize ctrl-arrow keys when using PuTTY? (FYI, I don't remember having this problem when using gnu-terminal in linux instead of PuTTY).
UPDATE: It appears PuTTY is the problem as it is not sending the escape codes that are necessary for this to work. I'm giving up for now and using Cygwin+mintty.
kbosak
  • 532
9 Answers9
34
As mentioned in here, u can put in ~/.inputrc:
"\eOD": backward-word
"\eOC": forward-word
It worked for me.
15
Edit:
Here's what worked for me:
  • My ~/.bashrc sets TERM=xterm (mine happens to be TERM=xterm-256colors) overriding screen's TERM=screen
  • I set PuTTY > Terminal > Features > Disable Application cursor keys mode to checked
  • I enter tput smkx at the Bash prompt
  • Now Ctrl-Arrow keys jump word-by-word
  • For informational purposes, if I do:
    tput smkx | hexdump -c
    I get
    0000000 033 [ ? 1 h 033 =
    and
    tput rmkx | hexdump -c
    gives me
    0000000 033 [ ? 1 l 033 >
I think there's a way to rework this into something a little better, but it's what I've got so far and it seems to work.
Original answer:
From info screen:
Each window in a `screen' session emulates a VT100 terminal, with some extra functions added. The VT100 emulator is hard-coded, no other terminal types can be emulated.
And VT100s don't have Ctrl-Arrow keycodes.
I'm somewhat surprised that you got Putty to send ctrl-arrowkeys correctly even without using screen, as that has never worked for me. My solution was to switch to using alt-arrowkeys (meta-arrowkeys), which I believe have the same forward-word / backward-word binding in bash by default, though I had to issue a couple extra commands for zsh to recognize them:
bindkey "^[^[[C" forward-word      # Meta-RightArrow
bindkey "^[^[[D" backward-word     # Meta-LeftArrow
Zed
  • 693
In case others find this old question like I did, a more recent solution:
Ctrl and arrow keys doesn't work in putty! What do I do?
putty inverts the sense of the cursor key mode on ctrl, which is a bit hard for tmux to detect properly. To get ctrl keys right, change the terminfo settings so kUP5 (Ctrl-Up etc) are the adjusted versions, and disable smkx/rmkx so tmux doesn't change the mode. For example with this line in .tmux.conf (assuming you have TERM set to xterm):
set -g terminal-overrides "xterm*:kLFT5=\eOD:kRIT5=\eOC:kUP5=\eOA:kDN5=\eOB:smkx@:rmkx@"
Note that this will only work in tmux 1.2 and above.
http://stuff.mit.edu/afs/athena/project/bsd/src/tmux-1.3/FAQ
Collin Grady
  • 141
I'm using the Terminal > Keyboard > Function Keys > Xterm R6 That helps with htop (f4 search etc ) function keys working as expected.
What I've found out is that, instead of using CTRL + arrow, ALT + arrow jumps words instead.
Dan
  • 21
I just experienced the opposite! For me, ctrl-left and ctrl-right did not have the desired effects in the command line, but they still worked in screen (and emacs). I think it has to do with the way your program inputs special characters. (I use MobaXterm now.)
My fix was simply adding these two lines to the .inputrc file:
";5D": backward-word
";5C": forward-word
(The ;5C and ;5D were what appeared in the command line when I used them before this fix.)
Ness
  • 113
You should look into the documentation of terminfo, ncurses, screen and putty if you want to debug/configure properly. Also bash shortcuts can be configured with inputrc. Look into the man pages of bash and search for inputrc.
Do you have the right character encoding in Putty ? If you connect to a server in UTF-8 and your putty is in standard charset, in vim, the arrow keys are written. If Putty is in UTF-8, you can move your cursor. Maybe it is the same in your case...
Dom
  • 6,873
In your putty configuration under Terminal -> Features, there's a few "disable" checkboxes. You may want to try disabling application cursor keys or application keypad mode -- sometimes putty tries to be "too smart" and sends control characters that aren't compatible with the server.
tylerl
  • 15,245
