I've got a bash script that rsync's two directories. Sometimes there's a change, odds are there's nothing.
I want to run a command only if rsync actually made a change (add/update a file). Otherwise I want to just skip it. Is there a return response I should be looking at?
If you use the -i option (and don't use the -v option), rsync will only print lines to STDOUT for any changes that were made. Depending on your script, this could look like
if [ -n "$(rsync -i /dir1 /dir2)" ]; then
  run_command;
fi
fukawi2
  • 5,494
