Typically my nginx config looks like this:
server {
    listen       80;
    server_name  example.com;
    <some long config>
server {
    listen       443;
    ssl                 on;
    ssl_certificate     qwe.crt;
    ssl_certificate_key qwe.key;
    <the same long config>
How to forward all https requests to http server directive (not send redirect to client but forward within nginx) so that I will not need to write the same config twice?
peterh
  • 5,017
Poma
  • 1,319
Found solution:
server {
    listen              80;
    listen              443 ssl;
    server_name         www.example.com;
    ssl_certificate     www.example.com.crt;
    ssl_certificate_key www.example.com.key;
    <some long config>
Poma
  • 1,319
You simply have two server directives...
  • One that listens on port 80 and does a rewrite
  • And another that listens on port 443 and is your main config
Of course you can do this the other way around (https redirect to http) it makes no difference.
In Nginx, how can I rewrite all http requests to https while maintaining sub-domain?
server {
       listen         80;
       server_name    my.domain.com;
       rewrite        ^ https://$server_name$request_uri? permanent;
server {
       listen         443;
       ssl            on;
Drew Khoury
  • 4,697
  • 8
  • 29
  • 29
