100
I'm having trouble understanding nested locations in nginx. I have two locations with some configuration directives in common, so rather than repeat the directives, I'd prefer to repeat the URI using a regular-expression:
location ~ /a|/b {
        location /a {
        location /b {
However, this gives the error
nginx: [emerg] location "/a" is outside location "/a|/b" in /etc/nginx/nginx.conf:36
Without the or | it seems okay, though.
location ~ /a {
        location /a {
What am I doing wrong? Is there a better way to do this without repeating anything? Can I group locations in another way?
Jayen
  • 1,907
Old question, but the issue is because the parent location is a regex location while the nested locations are prefix locations.
When a parent location is defined by a regex, any nested locations must also be defined by regexes:
location ~ ^/(a|b) {
        location ~ ^/a {
        location ~ ^/b {
You may only define nested prefix locations when the parent location is also a prefix location:
location /a {
        location /a {
               # You can also skip this location and just write
               # your code directly under the parent location
        location /a/b {
However, you may define nested regex locations when the parent location is a prefix location:
location /a/b {
        location ~ /a {
        location ~ /b {
Dayo
  • 1,936
