28
I've been searching around but couldn't find a straight answer, if someone could please clarify this, would be greatly appreciated, thanks!
location ~ \.php$ {
    try_files      $uri = 404;
    fastcgi_pass   unix:/run/php-fpm/php-fpm.sock;
    fastcgi_index  index.php;
    include        fastcgi.conf;
OR/AND?
upstream php {
    server         unix:/run/php-fpm/php-fpm.sock;
Thanks!
Van Nguyen
  • 628
  • 3
  • 9
  • 15
location is used to match expressions and create rules for them.
upstream defines servers that can be referenced to.
In your example this means if you want to get an equivalent for
location ~ \.php$ {
, you would need
upstream php {
location ~ \.php$ {
    fastcgi_pass   php;
The benefit of the upstream block is that you can configure more than one server/port/service as upstream and distribute the traffic on them, for example like this:
upstream php {
    server 127.0.0.1:8080       max_fails=3 fail_timeout=30s;
    server 192.68.1.2     weight=5;
You can find more information about this in the nginx documentation:
http://nginx.org/en/docs/http/ngx_http_upstream_module.html
chrki
  • 249
etagenklo
  • 5,994
  • 29
  • 33
I have found that, as of nginx 1.6.2 at least, the working syntax for me for the location block is:
location ~ \.php$ {
    fastcgi_pass   php;
that is: one should not specify the http:// protocol before referencing the php backend. The http://php syntax is to be used with the proxy_pass instruction, not fastcgi_pass.
Weeblr
  • 91
