I'm trying to configure my clinet 'Itai-test' to receive puppet settings from the puppet server which is called 'puppetmaster'.
On the server I ran:
[root@puppetmaster requests]# puppet cert --generate itai-test.domain
Error: A Certificate already exists for itai-test.domain
[root@puppetmaster requests]# puppet cert --sign itai-test.domain
Error: Could not find certificate request for itai-test.domain
On the puppet client I ran:
[root@itai-test temp]# puppet agent --server puppetmaster.domain --waitforcert 60 --test
Notice: Did not receive certificate
More information: On server:
[root@puppetmaster ~]# puppet cert --revoke Itai-test
Error: Could not find a serial number for itai-test
[root@puppetmaster ~]# puppet cert --revoke itai-test
[root@puppetmaster ~]# puppet cert --clean itai-test
[root@puppetmaster ~]# puppet cert --list
[root@puppetmaster ~]# puppet cert --sign itai-test
On client:
[root@itai-test ~]# rm -rf /usr/lib/puppet/ssl
[root@itai-test ~]# puppet agent --server puppetmaster.domain --waitforcert 60
[root@itai-test ~]# ping puppetmaster.domain
PING puppetmaster (192.168.X.X) 56(84) bytes of data.
64 bytes from puppetmaster (192.168.X.X): icmp_seq=1 ttl=64 time=0.294 ms
Itai Ganot
  • 10,976
Does you client know how to find the server?
root@client# ping puppet
What certname will the client use when connecting to the server?
root@client# puppet config print certname
Remove the ssl details on the client
root@client# rm -rf /var/lib/puppet/ssl
Remove all traces of the client on the server
root@puppet# puppet node clean $client_certname
root@puppet# puppet node deactivate $client_certname
ptman
  • 29,862
First: On Server
puppet cert --clean Itai-test
Second: On Client
puppet agent --server [puppetmaster domain name] --waitforcert 60
Third: On Server
puppet cert --list (you should see your host)
puppet cert --sign Itai-test
Also, double check that your client can reach your [puppetmaster domain name].
I think you got out of sync somehow. Assuming this is really just a test instance... On the server, run puppet node clean itai-test.domain. Then, on the client run rm -rf /var/lib/puppet/ssl. Now your SSL cert for the client is gone. Run puppet agent --server puppetmaster.domain --waitforcert 60 --test on the client and look for the certificate request on the server.
Bill Weiss
  • 11,266
