I've problem with enabling WiredTiger engine by setings in mongod.conf I'm using Centos 7, and this is my config
#/etc/mongod.conf
storage:
    wiredTiger:
        engineConfig:
            cacheSizeGB: 2
        collectionConfig:
            blockCompressor: snappy
    dbPath: "/var/lib/mongo"
systemLog:
    destination: file
    path: "/var/log/mongodb/mongod.log"
    logAppend: true
    #timeStampFormat: iso8601-utc
processManagement:
    fork: true
    pidFilePath: "/var/run/mongodb/mongod.pid"
net:
    bindIp: 10.0.1.136,127.0.0.1
    port: 27017
    wireObjectCheck : true
    unixDomainSocket:
        enabled : true
security:
    keyFile: "/etc/mongo.rs1.key"
    authorization: "enabled"
replication:
   oplogSizeMB: 2048
   replSetName: rs1
Mongo starts but the enginge is mmapv1 :( This is the output in mongo log
Detected configuration for non-active storage engine wiredTiger when current storage engine is mmapv1
I can enable wiredtiger only by manualy invoking command
mongod --storageEngine wiredTiger
Is it something wrong with my config file? I have the same problem on Centos 6.
EDIT: On Centos 7 I can enable WiredTiger by making systemd init script (Mongo3 comes by default with /etc/init.d script).
/lib/systemd/system/mongod.service
[Unit]
Description=High-performance, schema-free document-oriented database
After=syslog.target network.target
[Service]
Type=forking
User=mongod
Group=mongod
PIDFile=/var/run/mongodb/mongod.pid
EnvironmentFile=/etc/sysconfig/mongod
ExecStart=/bin/mongod $OPTIONS run
# Other directives omitted
# (file size)
LimitFSIZE=infinity
# (cpu time)
LimitCPU=infinity
# (virtual memory size)
LimitAS=infinity
# (open files)
LimitNOFILE=64000
# (processes/threads)
LimitNPROC=64000
[Install]
WantedBy=multi-user.target
And changing start options in file /etc/sysconfig/mongod
OPTIONS="--storageEngine wiredTiger -f /etc/mongod.conf"
So ok this way it works fine, but still why doesn't it work when it is configured in mongod.conf file?
B14D3
  • 5,308
  • 16
  • 69
  • 85
If I remember correctly, you have to have this in your config:
storage:
    engine: wiredTiger
Though I can't test it right now...
Edit: Found the same suggestion in How to migrate MongoDB 2.6 to 3.0 with WiredTiger
Fox
  • 4,047
