I have a need to create namespaces inside a Docker container. And as part of this, I will need to mount a /proc private to the inner namespace. I realize that I will have to run the container with certain privileges to make this happen, but I would prefer to enable the most minimal set.
This works:
$ sudo docker run --privileged --security-opt=seccomp=unconfined \
 -it fedora:rawhide /usr/bin/unshare -Ufmp -r \
 /bin/sh -c 'mount -t proc proc /proc'
This doesn't:
$ sudo docker run --cap-add=sys_admin --security-opt=seccomp=unconfined \
mount: /proc: cannot mount proc read-only.
So, just turning off seccomp filters and adding CAP_SYS_ADMIN isn't enough. What is enough?
Update: Selinux is a part of the problem. If you turn off selinux enforcement globally, it works. But, you can also turn off enforcement for a particular container with --security-opt label:disable, and this is documented in the security configuration section of the online Docker manual:
sudo docker run --cap-add=sys_admin --security-opt label:disable \
 -it fedora:rawhide /usr/bin/unshare -fmp /bin/sh -c \
 'mount --make-private / ; mount -t proc proc /proc'
But that fails if the -U and -r flags are added back to unshare. And, of course, adding --privileged to the docker run command works just fine even with the -U and -r flags.
I'm currently trying to use the kernel tracing stuff to figure out what, exactly, is giving me an EPERM. It's a very unhelpfully unspecific error to get.
Omnifarious
  • 400
  • 3
  • 15
This command works:
sudo docker run --cap-add=sys_admin --security-opt label:disable -it fedora:rawhide /bin/sh -c 'for dir in $(awk '"'"'/\/proc\// { print $5; }'"'"' /proc/1/mountinfo ); do umount "$dir"; done; /usr/bin/unshare -Ufmp -r /bin/sh -c '"'"'mount --make-private / ; mount -t proc proc /proc ; ls /proc'"'"
I didn't split it over multiple lines because the quoting is really important. Basically, it unmounts a whole bunch of stuff in /proc before running unshare and mounting /proc in the child user namespace.
Docker mounts over a bunch of directories and files in /proc with its own directories that are empty tmpfs directories and null files. Various files in /proc represent values that are applicable to the whole system. In fact, /proc/kcore would allow you to read kernel memory inside the container if you were root, which, since a lot of people want to believe that containers are some kind of lightweight VM or something, would surprise a lot of people.
The kernel in (as of version 4.14 anyway) fs/namespace.c:mnt_already_visible checks to see if you're mounting an already mounted filesystem, and if that filesystem has things mounted as child filesystems and those mounts have the MNT_LOCKED flag, it fails. The MNT_LOCKED flag seems to be applied (I didn't hunt down where this is in the kernel) to all mounts whenever you create a user namespace in order to prevent you from unmounting things in that namespace (because you get privileges 'within' the user namespace) and making hidden stuff visible again.
The command I posted uses an awk script on the contents of /proc/1/mountinfo to pull out all of the subdirectories of and files in /proc that Docker has mounted over, and unmounts them all. This makes the /proc filesystem mountable in nested user namespaces again.
LtWorf
  • 123
Omnifarious
  • 400
  • 3
  • 15
